charlie tuna
- Florida
ten years ago we installed two 75 h.p.toshiba variable speed drives in a hotel complex. the original system had bypass dampers that would maintain a designed duct pressure for system operation. we converted this pressure signal to control the speed of the motor and cut fan operating costs by fourty per cent. we had a happy customer, and the building engineers like the idea of taking the labor intensive variable dump dampers out of the system.
five years ago,during a lightning storm one of the drives failed and they contacted us to service the drive. the drive required factory service and they instruced us to find a replacement drive and wanted the original drive repaired and returned to use as a standby spare. at the time baldor motor company was advertising in electrical contractor magazines that they had a drive that was so good that if it failed during the warentee period they would replace it with a new one, repair the original unit and ship it back to the customer as a spare. i thought this must be a good drive and ordered one and installed it. it had all the same features that the toshiba drive had.
after three months of operation the baldor drive failed. by this time i had the toshiba drive back and used it to replace the baldor drive. the baldor drive was then air freighted back to their factory. the first said it was lost - then they found it but forgot to repair it - then said it wasn't supposed to get repaired because now the warentee expired - then said it was repaired but not shipped - and now they don't say anything!!! four years getting the run around. has anyone else had problems with baldor???????????????? this is an expensive piece of equipment!
