Wash/Dry/Maybe Fry
hillbilly
I was called to relocate a washer/dryer circuit on a older home that a freind of mine has rented from a friend of his.
The old "laundry" location was on a outside (covered) porch.
The breaker panel (200A) is in a bedroom closet, and the first thing that I see is a panel with about half the face blanks missing, only holes.
I remove the cover and find a 100A 2 pole breaker feeding the dryer!
Upon removing the dryer receptacle from the porch (face up in decking), I find that there is no box, only a hole in the floor with the receptacle screwed to it. The bottom of the receptacle was exposed. This was a porch that is open underneath and about 5' above ground. The #10-2 NM feeding the receptacle was run thru a hole in the block foundation and un-supported to the breaker panel.
The circuit was wired using the bare as a hot conductor and the white as the ground.
The washing machine was plugged into a duplex receptacle located under the porch using a extension cord. The receptacle wasn't GFCI protected, didn't have a cover, and the 12-2NM was "protected" by a 60A single pole breaker.
I also found (2) #14cu NM 230V circuits that had been used for space heating. These were also "protected" by 60A 2 pole breakers!
There was also (1) 120V circuit (#12cu) for the fridge that was "protected" by a 50A single pole breaker.
The old #6 cu SE cable feeding the range is suspended from each end (30') and the insulation if falling off. At least it had a 60A breaker.
In all my years, this is just about the worst case of "jake leg" that I've ever seen.
Talk about a coiled snake ready to bite.
steve
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Great description. Thanks.
One can only laugh. . .the "thinking" that went into that installation is such folly.
:rolleyes:
George Stolz
Windsor, CO NEC: 2017
Service Manager
What's wrong with that? I try to use as many single-pole 60A breakers as I can in a house. Bigger is always better.
That is a joke, for the people in Peoria.
celtic
NJ
The last "friend " (the LL) had better seriously consider hiring someone to evaluate and make the neccessary repairs.
The LL stands to lose their investment (and possible more) if, and when, something goes horrible wrong (fire, death, etc).
