ryan_618
- Salt Lake City, Utah
I was contacted via email by a gentleman that had a few questions. I told him I would post his questions here, so that a broader range of replies could be given. Please share your thoughts, if you can, on the following questions:
I am the electrical design engineer for upgrade of Digesters at a Waste Water Treatment plant and I desprately need your input on the grounding of the Gas Domes on the Roof of the Digesters. The gas dome is a metal structure installed on the roof of the concrete digesters, which houses some gas piping routed from the digesters to other location. The gas domes are included with 120V electrical equipment (lighting, receptacles,...). The area where the gas dome is located is class 1, Div 1.
My question are:
1. Is grounding of the structure a good practice or not? Unfortunately the OESC is not very clear.
2. Can we ground the structure through a grounding rods installed in vicinity of the structure?
3. As there are 6 digesters installed side by side but gas domes located in the center of the digesters are far apart, can we install separate grounding rod for each dome?
4. How do we have to make bonding between this structure, gas piping and electrical equipment enclosures installed in the dome?
My question are:
