Wasted Cable???
Drifter88
New member
Last week I helped a friend of mine who buries cable (RG11) for a subcontractor for Charter. I was AMAZED at how much cable is thrown away. Between running a new line to the house to replace the one someone just before him ran for temporary service and the amount left on the real that usually isn't quite enough for a new run. He throws it all in a dumpster at Charter and I assume they recycle it. Does anyone know exactly what they do with it and why it can't be spliced and reused? I know a new reel must cost $150-200. Thanks
First of all it doesn't cost that much when you buy it in the quantities they purchase. Second, you never want to splice, especially underground if you can help it. Third, there is extremely little copper. It's a little bit of aluminum and a lot of plastic so it has little scrap value. I don't know if it is even recycleable.
-Hal
Drifter88 said:
... and I assume they recycle it...
You bet they do.
Trying to splice short lengths of coax together isn't cost-effective in the long run. Making up the splices requires connectors and labor time...it's faster just to pull new cable.Also, the spliced cable will end up being less reliable, especially outdoors, aerial or buried.
peter d said:
But it is recyclable nonetheless. If it contains copper, no matter how small the amount, it is recyclable.
many plastics are recyclable also, you just cant seem to get anyone to pay you for it....
while all the focus is on the scrap price,,
the splice is totally out of the question. Charter is my third largest customer preceeded by Comcast and Time Warner.
The last thing you want is a resistive addition to an already competitive market. Splices will decrease speed. there are tools for fiber pairs where you can see the splice through means of an OTDR. Imagine being able to see a splice or a crack in glass miles away!
similair test equpment is used to detect signal degredation on telecom wires and the such to make sure the customer is correct and the trouble is on the outside plant side and not the inside wire.
Also,, you would not want the public to know that "charter does not throw anything away, and your sevice will be sold to you with about 500 splices before it ever reaches your computer/television"
Talk about a NasDaq nightmare
lvz2fsh said:
the center conductor in coax isnt even close to being pure copper.......it will rust fairly quick...
That's Copperweld. It's copper-clad steel. Skin effect at RF's make solid copper a waste.
Meaning that it's steel wire with a thin plating of copper. I doubt it has any value even with copper fetching better than $2 a pound for uncleaned wire.
Most of our scrap goes to China. I bet they would take coax scrap if somebody was willing to collect it but I don't think it would be cost effective.
-Hal
