aelectricalman
- KY
When is water grounding not necessary? Is it always required in new construction? I have one inspector that requires both 1 ground rod and one water ground or 2 ground rods and no water is needed. The other says that 2 ground rods must me driven and also a water ground is needed.
My question is this. If the plumbing is leaving the home in plastic or PVC or whatever else it is that they use, can I just have the 2 ground rods seried 6 feet apart, or do I need to add a third ground rod seperate from the other two seried electrodes to accomidate for the lack of water ground.
Secondly, if the lightning is going to ground the fastest way possible, won't one of the systems be useless. Why is the water ground mandated if only one system will truely carry the load to ground. Am i wrong in my assumption or is it so it picks the bast of the two.
Editted because I have not passed hooked on phonics course.
[ February 22, 2005, 07:03 PM: Message edited by: aelectricalman ]
