fishingmaniac
- Hull, Mass
If adding a 220v water heater in the typical unfinished basement utility area for a single family residential occupancy with a two pole 30a with romex 10/2 with gnd run from panel to heater,
is it a violation to run that romex directly into the water heater, or must you use a box and change over to greenfield, or is it up to the inspector?
