was just informed by an inspector that my water heater configuration is not up to code.
It is an endless hot water heater. uses 4 -30 amp 2 pole breakers. I have a 200 amp panel located in the garage,and the 4 breakers are located in it. the panel is 5 feet from the water heater ( withen site). I was told that I could not hard wire the heater straight to the panel and that the disconnects had to be withen 6 feet of the heater.I from texas and the code that is current is the 2005 edition. I believe that 422.31(A)allows me to hook it up straight to the panel . if there are any opinions out there please let me know
Thanks Will D
Thanks Will D
