Water heater inside electrical room
anbm
TX
Designer
We share electrical and mechanical room. Is it okay to locate water heater in front of main electrical gear? (If we meet the clearance per NEC 110.26)?
Just curious if the water leak...sound likes it is not a good idea to locate them in same area?
I wouldn't worry about it. Mechanical rooms are usually full of electrical equipment along with water, sprinkler or steam pipes.
Actually - aside from a spraying leak, there is more risk if the water heater were on a floor above the electric equipment and started leaking than there is just sitting in front of the electrical equipment.
plus, you need somewhere to lay your tools as you work in the panel :D
