etbrown4
- United States
Been doing plumbing and electrical work for nearly 40 years and here is a new one for me.
50 gal elec water heater, maybe 3 years old. Rated 4500w
It is pulling 18a on both hot wires supplying the heater so that's at 230v, measured by an Amprobe.
There is no leak and the T&P is not leaking either.
One wonders how a heater can draw it's rated current and not heat water.
Elements test ok. Resets are not tripped.
I know there can be issues with broken dip tubes and cross connections, but can't really see how either could apply here.
I also know that the situation I describe should be a physical impossibility, as current drawn is current used, and will yield an equivalent amount of heat into that water!
Tips appreciated
Water Heater Pulling 18 Amps Continuously - Not Heating
Tips appreciated
