JDB3
- San Antonio, Texas
A plumber friend call this afternoon about a 125 gallon single 240 volt water heater that they installed. This water heater has taps so that it may be hooked up for 208 or 240 volt. The manufacture rep. said that the taps are hooked up properly for 240 volts.
The water heater is feed from a 240 volt 30 amp power source, which is feed from a step down transformer. The water heater has 2 4500 watt elements that do not work simultaneously. The water heater has 2 30 amp fuses built into it (I was told that they are time delay fuses).
The water heater will work fine when they leave, but in a week or so, a fuse will blow.
I was told that the customer also has had trouble with the A/C system.
Any thoughts ?
Thanks,
Any thoughts ?
Thanks,
