Water heater test question
tortuga
Code Historian
Oregon
Electrical Design
Greetings all I am interested how you all answer this question:
A standard residential 50 gallon water heater has two 4500 watt elements that operate non-simultaneously.
The markings on the water heater indicate 240 Volt, 4500W, copper conductors only.
The manufacturers literature that comes with the water heater has a table for recommended sizing the breaker and wire.
The table lists 10 Awg copper and a 25 amp breaker for this unit.
The breakers are marked for 60/75 C terminations.
If the wiring method chosen will be type MC cable what is the minimum branch circuit conductor size permitted by the NEC?
A) 10 AWG
B) 12 AWG
C) 8 AWG
(A) is correct 10 AWG , the water heater is a continuous load per 422.13 and since 240.4(D)(5) limits 12 AWG MC to 20 amps and table 240.4(G) only references 'motor operated' appliances not all appliances.
That is a well written question.
I would start with understanding what it is asking. In this case the keywords for me are.
I would start in 422.
In this case 422.13 storage type INF note go to 422.10
part 2 installation
422.10 (A)
marked rating
On to 422.11, (A-G) over current protection.
422.11 (A)
Says to go to 240.4 plus marked rating.
Off to 240.4 😗😗😗😗
240.4 (D)
Use (D-1 thru D-7).
Unless E or G apply.
Neither do apply.
So back to (D) 😗😗😗😗
1 nope
2 nope
3 nope
4 nope
5 🤔🤗
Plus I cheated; cliff note
I agree it is a good question and as it contains some irrelevant information to possibly confuse you. When I look at a question like this I try to start with what's relevant and what's irrelevant to finding the correct answer. I outlined my process below. Bold/Black relevant, Bold/Red irrelevant.
A standard residential 50 gallon water heater has two 4500 watt elements that operate non-simultaneously. The markings on the water heater indicate 240 Volt, 4500W, copper conductors only. The manufacturers literature that comes with the water heater has a table for recommended sizing the breaker and wire. The table lists 10 Awg copper and a 25 amp breaker for this unit. The breakers are marked for 60/75 C terminations. If the wiring method chosen will be type MC cable what is the minimum branch circuit conductor size permitted by the NEC?
