Boss wants a new water heater installed. I have 208v 3ph in the location he wants it. Am I stuck buying a more expensive industrial 208 3ph heater, or are there cheaper options. It needs to be at least 40 gallon, and the 3ph models are not cheap.
I know they used to. I have connected them in apartment complexes a few years ago.Do they make 1Ø, 208 volt HWH's?
Notice at the bottom it says “watts 4.5”I know they used to. I have connected them in apartment complexes a few years ago.
they do make 4500 watt 208 elements.
Change them.
Edit: found one
"Burn-out proof"Notice at the bottom it says “watts 4.5”
I’m sure at 4.5 W it would be"Burn-out proof"
You need to determine what the demand will be for hot water. Why does he want a water heater?This is a new install. I just wanted to utilize to power source I had available at that location. I guess what I want to know is can I use the 3ph 208v that I have available on a single phase residential unit. There is about $1k difference in price from 1ph to 3 ph.
Didn’t think of asking for usage..You need to determine what the demand will be for hot water. Why does he want a water heater?
Occasional hand washing you could get by with a 120v 5 gal unit, but they are almost the same price as a residential 40 gal electric.
Also, when I clicked on the "specifications" link on that page it took me to a gas water heater specification sheet.Notice at the bottom it says “watts 4.5”
Yes just use 2 phases of the three phase. This is done all the time. As has been said, if you are concerned about the lesser wattage, change the elements. As an alternative, usually the better 9 and 12 year units come with 5500 watt (@240) elements which would give you about 4200 @ 208. Done.This is a new install. I just wanted to utilize to power source I had available at that location. I guess what I want to know is can I use the 3ph 208v that I have available on a single phase residential unit. There is about $1k difference in price from 1ph to 3 ph.
