I'm doing a job at a healthcare facilitie.I have to install a circuit for a 30 gallon water heater.The only info on the name plate is 2000 watts 120 volts.To find the wire size I divide 2000 watts by 120 volts and get 16.6 amps.I times this by 125% and get 20.8 amps which tells me I must use a # 10 wire.
I was looking in one of my workbooks and it said I could use a #12 wire from the 60 degree columb which is 25 amps for this circuit because at the bottom of table 310.16 at the daggar 240.4(D)does not apply to appliance circuits.Could I have run a #12 wire and be legal in this case?
