Water Intrusion
TwoBlocked
Bradford County, PA
Industrial Electrician
Two sets of motor leads for some 480v brine pumps on VFDs. (Yes, they are not VFD cables and, and, and...) The one VFD finally tripped on ground fault, but the other kept going. AND when the non-electricians tried different things to get stuff working, they got some shocks from wires that were supposedly dead. They said they could hear sizzling from within the j-box. You can see the high water mark in the first picture and the new drain holes in the third. I think the water was coming from the loose cover, not necessarily from the j-box above and down through the conduit. I sure do like these Buchanan connectors with wrap caps. I used the large ones and a ratcheting crimper. It was #6 wire. I expect many more trouble calls to this facility.
