not sure about the point you just made... have seen many ceilings over the years with space between them and the subfloor above and no connections... usually insulated between as well, with fire board on the sub floor... all the apartments stuff in their ceiling area separate from the floor above... yet it was still a structural ceiling..studs run across... usually in older buildings that had over eight foot ceiling heights and they built new ceiling at 8 foot... hiding wiring runs, plumbing etc within the cavity.
In those, because the ceiling is dropped but structurally built rather than using wires and metal grid, I would call it a structural ceiling...
