Cub57
- Brownwoodtexasus
Is this a mandatory requirement since most plumbing is pvc or pex now
If the water pipe does not qualify as an electrode there is no water pipe electrode to connect to.
Roger
Even though most existing water lines that are abandoned still have a stub sticking through a basement wall, just no way to know if it still qualifies as an electrode
Then it is not an electrode.Even though most existing water lines that are abandoned still have a stub sticking through a basement wall, just no way to know if it still qualifies as an electrode
It is no longer a 250.52(A)(1) electrode. It can still be a (A)(5) electrode.Then it is not an electrode.
Sent from my SM-T350 using Tapatalk
Can be. I believe that there was a question as to knowing 'if' it still met the requirements.It is no longer a 250.52(A)(1) electrode. It can still be a (A)(5) electrode.
Those become 250.52(A)(5) electrodes instead of (A)(1) electrodes once they are no longer a water pipe, if there is at least 8 feet in the ground, which you may or may not know how much is there.
Nobody is going to enforce it, but say it was an (A) (5) what difference would that make if it is present?
