this job is in Massachusetts, residential home, upgrading a service to a 200 amp, installed my 2 supplemental grounds outside, there's an existing ground rod below the panel which I will bring a #4 copper wire. My question is this. All the copper piping and water meter in the house is feed by a piece of plastic piping coming out from the basement floor from the street. Do I need to bring a wire from the panel to ground the copper piping ? If so what size? The meter is 30 feet away, the copper piping comes over to the water heater where the panel is , can I ground there? Thank you
