I recently installed a new 150A service panel into and old house, replacing the old service panel. I connected the neutral and ground busses to both the incoming copper water supply pipe (within 5 feet of its entrance to the basement and on the incoming side of the meter) and to an 8' x 5/8 ground rod and the bonded the busses to the panel. I didn't check the impedance to ground, so it may have been more than 25 ohms, but the Poco claimed that I needed 2 ground rods, more than 8' apart. They didn't cite the possibility of too high an impedance to ground, the problem was that the water supply pipe is no longer able to be used as a grounding electrode as per a change in the NEC in the last 12 months. I do my best to keep up with late breaking code changes...did I miss something??? HELP! Thank you.
