just received a call from a plumber who is adding a new water service, the new is pex, old is galvanized,
electric service has one driven ground and is bonded to the water within 5 feet of water entering the building.
plumber is going to leave the galvanized pipe in the ground more than 10' outside of structure
Question : if leaving the galvanized pipe with the bonding intact does there need to be another driven ground?
i'm thinking it is not required
your thoughts appreciated, BTW the code cycle is 2011
