We have an industrial machine electrical panel that that has a 480VAC transformer in it as well as some high and low voltage wires from a high powered laser passing through it. The laser has water cooling lines (nylon reinforced plastic tubing which carry DI (deionized, non-conductive) water which we would like to let pass through the enclosure. There would be no joints or fittings in the lines where it passes through the enclosure. I have a copy of the 2005 NEC code book and do not see this addressed.
Is there code addressing this situation?
