ChopperDan
New member
I have been an electrician for along time but now work for a fire alarm company.
What I have is a water flow switch wired to the FACP (low voltage) with FPLR. We are good there. Now a 120v bell must be added and I was being told to use the extra contacts on the existing switch.
Art 300.3.c.1 States that it can be done if the insulation rating was of the higher voltage (it isn't) or fpn 725.55 I fail to see anything in 725.55 allowing this.
I'm looking for your thoughts on this.
My solution is to add an addressable relay, map it to the flow sw, program it as no silence able and use it to switch the bell power.:grin:
Thanks,
Dan
Thanks,
Dan
