watt-meter
Flight987
If you have athree-phase ciccuit where a watt-meter reads 11,040 watts, a voltmeter reads 460 volt's, and the
power factor is 81%, how much current would be present in the circuit? This is from a Prac. test and I have the
answ. and have no clue on this one.
Why is it
Why is it
Why is it that we don't take VA/(460x1.732) =Amp's. Is it because we are using EFF.? I take what I just said
is that, that nothing is 100% EFF. I feel dumb to see such a simple fix. Could we take 11,040/ (460x1.732) x
.81 and get the same result? I will try that and then go back to look at your work.
That IS what I did.
Efficiency doesn't enter into the equation. 11,040/(460x1.732x0.81) will be the same as my work.
