rickymcc
- Murfreesboro , Tn
Can someone tell me the formula for figuring the wattage of a three phase heater bank. I know the voltage and the resistance between each phase hook-up. The heaters are not marked and i wish to calculate this to order the correct wattage bank.
I know ohm's law, but i don't think i can use it on a three-phase problem without some substitution. This knowledge would also be helpful if you needed to size conductors to the bank. If more information is needed let me know.
The resistance between conductors of the heater bank is 24 ohms. The voltage is 240v phase to phase.
