Good Evening:
I hope some one can help me understand the following question:
The Lamps are rated 60 and 100 watts respectively. When Connected in series,
a. Each lamp takes the same power
b. The 60 watt lamp takes more then the 100 watt lamp
c The 100 watt takes more than the 60 watt lamp
d. Both lamps take more than 60 but less than 100 watts.
I picked letter C but the answer key says its B. Thank you in advanced for your help.
