rcwilson said:VA & watts are the same.
I'm curious. Why is it you think that?barbeer said:IMHO this statement is flawed.
Watts and VA can be broken down into the same fundamental units of measure, kilogram-meter squared per second cubed, but they are not the same thing. In a resistive load, their numerical values are the same, and you can essentially equate the two. In a load with inductance (e.g., a motor) or capacitance, the two will have different values, with VA always being a larger number than watts.rcwilson said:Yes. VA & watts are the same.
charlie b said:Watts and VA can be broken down into the same fundamental units of measure, kilogram-meter squared per second cubed, but they are not the same thing. [/quote]
Oh - I see what you mean.
I had translated that rc was saying that 120V VA was the same as 240V VA and 120V Watts was the same as 240V Watts.
cf
j rae said:would a220v A.C. unit use the same amount of wattage as a 120v unit since
P=IE and wouldn't the 220v unit use 1/2 the amps????
LarryFine said:Oh, good grief, Charlie Brown. Is this the start of another 50-page thread?
If BTU per watt is the same for both, the cost of running will be the same.
However, the 240v unit has the potential to be more economical to wire.
But that would have been the wrong answer. Let?s take another look at the original question.weressl said:This thread could have ended with a simple one-post-answer: Yup!
Let me put two AC units on a table. One is rated for 220 volts, includes a 3 hp motor, is about 3 feet wide, weighs about 150 pounds, and would take about 2 hours to cool my master bedroom. The other is rated for 120 volts, includes a 1/2 hp motor, is about 18 inches wide, weighs about 40 pounds, and would take about 8 hours to cool my master bedroom. Back to the original question: Do they use the same amount of wattage? I think not.j rae said:would a220v A.C. unit use the same amount of wattage as a 120v unit . . . ?
charlie b said:But that would have been the wrong answer. Let?s take another look at the original question.
My point is that the fact that the voltage is different does not tell us that that is the only thing that is different. We have been assuming too much about the intent of the question. This is not a simple matter of, ?if all else were equal,? because there are too many aspects of an air conditioner that could be different from unit to unit. There is no basis for making a simple comparison.
With apologies to the OP, this was not a question that is likely to get you to where you are trying to go. Can you try again to tell us what you want to know?
weressl said:The greatest folly of engineers to wait for all the data to come in. That's why they never get anything done......and I can say dat because I is one.......![]()
drbond24 said:I disagree with that statment. I get a lot of stuff done because when I don't have all of the necessary information, I A-S-S-U-M-E. :grin:
Of course, I would never actually use that word. It would be an 'educated approximation' or something like that.![]()
Thank you. I like to use few words to say a lot.iaov said:I think Larry hit it.
weressl said:OK, now you are with us.
It was safe to assume that the OP was talking about the same application.:roll: Nu?
