BJdittman
New User
- Maryland, USA
- Electrician
If anyone is knowledgeable about the Wattstopper ELCU 200 in conjunction with the LMRC 211 I have a question based on the current desires of the customer.
Modules Used:
ELCU - 200 (Emergency Control Unit)
LMRC - 211 (Control Panel)
LMSW - 101 (One Button Light Switch)
LMDC - 100 (Occ Sensor)
LMCT - 100 (Programmer)
Customer Wants: When the fire alarm system goes off for any reason they want the Emergency Lights in the building to go to 100% no matter what.
They are only providing one circuit for us for the ELCUs, is it possible to share the same circuit for emergency and normal power? We cut the test loop wire (Blue wire) and put it on an NC Relay circuit in the Fire Alarm System. Everything seems to work just fine but when the Fire Alarm goes off, or we disconnect the Test Loop the lights on the emergency only shine very dimly, making very little difference in a dark room. If you disconnect the dimming wires from the Emergency Lights during that state the lights shine at 100%.
Is there something in the programming? Something wired funny?
Modules Used:
