waveform question
drbond24
This is a waveform capture from out main switchgear that I took last year. Can anyone tell me what would cause the dimples on the peaks?
Harmonic distortion from non linear loads?
What the others have said, non-linear loads.
In particular, rectifier input loads have a diode followed by a capacitor. The load will only draw current when the supplied AC voltage is greater than the DC voltage in the capacitor. So instead of having a nice sinusoidal current flow, you have spikes of current which only flow right at the supply voltage peaks.
So you have this sudden surge of current flowing only at the AC peaks...this current flow causes a voltage drop on the impedance of the supply, distorting the supply voltage. Thus the dips in the supply peaks.
The above ignores a bunch of stuff, such as the impedance and inductance between the measurement point and the loads, and is just a handwaving description.
-Jon
Hey, you can't do that on live loads:grin: Unprotected line to switchgear? Life in prison! Castration!
:roll: :grin: :cool: :grin:
Thanks for the information gentlemen.
Oh ok. Next time I go download a waveform I'll put on a spacesuit before I plug into the port on the outside of the dead front switchgear. :grin: Wouldn't want OSHA to catch me being a nerd within 3 feet of the switchgear without proper PPE. :grin: :rolleyes:
