electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
For a given size OCPD, can one use 75 degree sized wire for the terminations, and then splice these stubs to smaller wire sized by the 90 degree column, assuming the splicing device and wire is rated for 90 degrees?
Example: The situation in the "#2 AL feeders" thread (http://www.mikeholt.com/code_forum/showthread.php?t=82086) where 310.15(B)(6) was used in a commercial application. Use a 1 foot piece of #1 AL on the 100A breaker and splice it to the #2(100A, 90 degree column), then do the same on the other end?
For smaller circuits, I noticed that Ideal wire nuts are rated 105 degrees, but I couldnt find a temperature rating on a split bolt.
I dont need to do any weaseling right now, just an academic question.
