Can a Red Dop weather proof box be attached to an exteior wall by screwing throught the back of box, with out using the tabs?
I would sure hope so, many of those type boxes even have places that can be punched out for mounting through the back.
I agree with you 100% but wonder if you have ever been able to "punch" one of those spots. I always ended up drilling.![]()
My best success with most of them has been a center punch and hammer, not a linesman pliers, it just doesn't have enough mass to get the job done, and strike it fairly hard, not full swing hard, but pretty hard.
If you use a screwdriver, or other tools you usually will have difficulty. If you did not strike hard enough center punch leaves a point for trying again, a screw driver just slips and sometimes messes up the nib making it hard to position for a second try.
Thought those were one in the same tool![]()
worked with a guy, that his only tools were linesman pliers & a screw driver. OK, yes that was back in the 70's !!
Caulking around the box, IMO, is a technical violation, as the NEC required a small space between the enclosure and the wall. That's why the boxes have those little tabs at the corners.
I stopped using the bell boxes. I now only install plastic FS boxes. Florida sea coast is ruff on the bell boxes.
