I have seen them in UK (UK 230V)Do they make a 120 volt dimmer suitable to dim LED bulbs and rated for outdoor use?
Thanks in advance.
IMO, technically no.All the dimmers I can find say, “indoor use only”. Does adding a weather cover change their rating?
You could use a toggle-style dimmer and a Wx cover that has an actuating lever.
I’ve done that before using a slide dimmer, the lever inside adjusted the dimmer from off to full on depending on the position of the handle.You’d have to take the cover off to use the dimmer. Lutron Pico is the way to go.
I would need to see some documention that states that the inside of a box installed outdoors is compliant with something label indoor use only."Indoor use only" is another way of saying "dry location use only". The interior of a weatherproof box with a proper weatherproof cover is a dry location.
infinity said:"The interior of a disconnect is not a wet location. It's that simple."
If it is, then why require Weather Resistant Receptacles in a Weatherproof enclosure?"Indoor use only" is another way of saying "dry location use only". The interior of a weatherproof box with a proper weatherproof cover is a dry location.
I like your thinking but indoor only means indoor only. I don't see any mention of dry location in “indoor use only” from post #7.I found this Discussion which I believe supports my position including this quote from you:
I have as well. While there is no Code Requirement for outdoor switches to be WR rated (as far as I'm aware), only certain receptacles, it stands to reason that said requirement should also apply to switches... but alas the world keeps turning and people want their patio string lights, lol1. Dimmers are clearly not meant for outdoor use.
2. I would do it anyway, and I have, many times.
And by "companion," you mean "slave?" Do my eyes deceive me or is an electrician actually being somewhat PC?I think it would be a more robust setup to have a Lutron Maestro dimmer located indoors that's connected to a Maestro Companion dimmer at the outdoor location.
I believe Lutron has always called them Companion or Accessory dimmers.And by "companion," you mean "slave?" Do my eyes deceive me or is an electrician actually being somewhat PC?
www.circuitstoday.com
