It seems like I’ve previously seen in the installation instructions information about installing drain holes in the bottom of the box for moisture/water to escape.
Another electrician and I were talking about caulking the box and I mentioned installing drain holes. I didn’t see any information in the box that I was currently installing at the time about it though.
I’ve definitely opened up WP boxes that had a bunch of water in the bottom of the box causing tripping issues with the receptacle that was installed in it.
Questions-
1) Do you caulk the box?
2) Do you drill out drain holes in bottom of the box?
3) Do you mount the box with the included brackets that come with the box or do you just drill out the back of the box and use a drywall screws?
Questions-
