Weatherproof In Use Receptacle
steve66
Illinois
Engineer
Does anyone make a while in use receptacle cover large enough for a 60A receptacle and plug???
Try This
Thanks Dennis. I had pin and sleeve devices in mind too.
The only problem is, these have to fit either in or on the decorative base of a light pole. And of course, the client wants something small and simple and inexpensive.
I did find some Pass & Seymour twist lock receptacles that have weather protective boots. They aren't 60A, but they are 50A. That may have to suffice.
Here is a link:
http://tools.passandseymour.com/pdf/I32.pdf
Small and simple. Would really like it to be unnoticeable when not in use.......
I know, a portable generator. When not in use there will be no signs of it at all.
