Weird looking fuse
Tainted
New York
Engineer (PE)
I went to survey a building and found service switches that have a very thin piece of copper acting like a fuse.
Just wondering what are these called?
If the fuse is blown, is there a way to replace it? Would it be extremely difficult or impossible to get a replacement fuse of this kind?
Are you sure it is a fuse? Might be a shunt resistor for measuring current.
If it is a shunt resistor it will likely have another marking on it like 100 mV. This would indicate 100 mVolt drop at 1200 Amps.
Very old open style overload fuse. Definitely not current limiting.
When it opens, the melted metal and combustion products will be everywhere in the switch.
That's wild, never heard of those before for LV applications. They do typically use a similar thing called a isolating link in series with the bayonet fuses in pad Mount transformers:
Looks like a old Bussmann WHA-D-1200 'Open link' Fuse.
There is some interesting history there.
Easy to remember the part number becasue your like what da heck is that?
