Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I was called to quote a panel change. It's a 150 amp NEMA 1 panel installed flush on the outside wall of a manufactured home with an independent weatherproof door installed over top of it. The door is hinged at the top. The panel is only 12" wide and the cover is 14.25" wide. No current panel product will fit in there and I haven't found a retrofit guts kit that works either.
Question 1: I'm curious if the installation the way it is is code compliant.
The best solution I can think of is to use a NEMA 3R panel mounted flush in the wall. I would put a piece of plywood behind it to make it stick out enough for the weatherproof door to open and close. I would seal it with silicone. I would punch KO's in the top for the cables coming from the top.
Question 2: What's your solution?
