hillbilly1
- North Georgia mountains
- Owner/electrical contractor
Had a new brain twister today, a friend of mine has a camper set up for one of his workers, he had replaced the light fixture over the vanity with a flouresent. The light worked fine while turned on, but when it was turned off, it would flash once about every 30 seconds. Put my meter on it, and there would be no voltage on it at first, then it would steadily grow to 25 volts, flash, then start over at zero again. Turned the main off in the panel, the lights would blink then come right back on. Found another breaker in the panel that was back feeding. turned it off. The light still would flash at regular intervals. Checked voltage at the panel, 120 v neutral to hot, but nothing between hot and ground. Neutral to ground was 120 v! Aha! either the camper was not grounded and a circuit was shorted somewhere. But no, camper was grounded, found a plug in the luggage compartment that somebody had wired to the park power supply cord and had reversed the polarity on the receptacle they had installed in the compartment. Fixed that, the 25 volts went away, everything things good now, right, wrong. Turned on the breaker that had been backfeeding the panel, the range hood began to spark and smoke. My friend failed to mention that they had a problem with it and had cut the wire, but did not insulate it. Since the polarity was backwards before, the ground being common with the neutral, there was no boom boom when it was shorted, when I corrected the polarity it then properly tripped the breaker. Apparently the short was on the load side of the fan causing the phantom voltage.
