Coppersmith
- Tampa, FL, USA
- Electrical Contractor
Today I was troubleshooting a split phase panel where all the 240 volt circuits were down. The main breaker is bad. I can hear it arcing occasionally. I got some weird readings I don't understand. Perhaps someone can explain.
I got 240 volts across the line side of the main as expected.
When measuring on the load side of the main, either hot to neutral read 120 volts, but hot to hot was zero volts.
I don't understand how this is possible. I would expect one side to be zero and the other to be 120.
