Alwayslearningelec
- NJ
- Estimator
Ok so I am clear.Typically they have a cord and plug. On the job the contractor using the welder provides a temp drop that gets installed in a panel. Often these units can be set up for different voltages (208 and 480) and single or three phase. The cord and plug with match how the unit it set up.
Typically the drop has a receptacle on it. (Sometimes the unit has just a cord that is hardwired directly to a panel). This ensures that the electrician just has to match the receptacle configuration to the voltage and number of phases. It also means that when the welding machine shows up on site it can be plugged right in and the welder can immediately start welding.Ok so I am clear.
1. welder provides temp drop that goes from panel to cord and plug on unit?
And hang it out of a panel using a Kellems grip.I would use SO for a rugged application like this, not romex.
Most of them have plenty of extensions if they need them, if welding is something they do on a pretty regular basis.a centrally located outlet with a receptacle and the welder provides his own extension cord length as needed.
Yes, that is why I suggested. Often the welder uses a generator so extension cords are a necessary tool they generally carry.Most of them have plenty of extensions if they need them, if welding is something they do on a pretty regular basis.
Depending on the site and other circumstances, should there be some heavy enough circuit that is not currently in use it could be possible to temporarily use it even if minor modifications are necessary for short term.
