Hello all. This is my first post here. I've been reading through the archives and have found you all to be very informative. Thanks for the discussions.
On to my question...
I work in a very old factory (built circa 1930). The electrical system is an ungrounded delta. We have an unsophisticated ground-fault detection system (3 lamps), but from what I've been told, they are only connected to the older part of the building. I'm not sure this is a true statement because we only have one power source from the utility into the main distribution building. From that main disconnect panel, we have several breakers feeding the older building, and only one feeding the newer building. There are no isolation transformers.
In the newer building we have had several people receive quite a jolt when they touched a welder with one hand and a piece of equipment steel with the other. The welders are wired for single phase 480V. The welders do not have to be turned on for the shock to occur.
Can anyone tell me what is causing this and what I could do to prevent it?
