Sr. Engineer
New member
- Thorsby, Alabama
In several of our plant areas welding cable from the welding machine to the work area is left laying out all the time. Is there anything in the NEC or other code that determines if welding cable must be in conduit. In serveral areas the welding cable has been ty-rapped to beams, etc to keep it off the floor. I am looking for something in the NEC or other code that would require the welding cable to be installed in conduit. If it is in conduit how do you then determine the ampacity rating and required conduit side?
