MG WRIGHT
- Phoenix, Arizona
I would like to see a visual on proper methods of grounding a well case.
What do you do?MG WRIGHT said:I am in the electrical industry...
I can't understand why some electricians are reseptive to giving electrical work away to unqualified personsons.
Remember, it doesn't have to be used for a grounding electrode. 250.52(A)(1) permits the use of the casing when trying to get 10' of metallic water pipe, if desired.eric stromberg said:I was thinking about the well casing the other day and was wondering if it was connected to the GES. It doesn't appear to be.
M.G., welcome to the forum.MG WRIGHT said:I was recently introduced to Mike Holt's Forum by a fellow reviewer in another municipality.
You might try to change your password to something memorable, and use the same screen name for home and work. You're easier to remember that way.I intend to open an account at my office work station in the next few days now that I've obtained approval from our IT department.
romeo said:Georgestoltz I require some kind of box at the top of the well casing. I like to have the connections made in a box and not inside the well casing,I have seen too many rusty wirenuts inside of well casings. I am aware that there are wire connectors made for the purpose but are not always used.
I'm picturing this: The casing is bonded through the fasteners holding the bell box on the casing, through the box, through the (greenromeo said:Georgestoltz I require some kind of box at the top of the well casing. I like to have the connections made in a box...
Nope. I can't imagine how big the lug would be for that. :shock:Scott said:Anybody ever use a 6" ground clamp?
