Well pump wiring in house
Aerowoot
New member
Pittsburgh
Hello,
I had a well dug some ten years ago and the guy ran the feed for the pump from the pressure switch to the breaker panel in the house with 3 wire 240v twisted pump cable. It was suitable for direct burial. I'm putting a new breaker panel in the house and was wondering if that 3 wire has to be in conduit inside the wall where it goes through the floor up to the breaker panel. Right now it goes through a NM clamp and into the panel.
I appreciate your advice.....Thank you in advance.
I am closing this thread in accordance with forum rules. This forum is intended to assist electricians, electrical contractors, inspectors, engineers, and other members of the electrical profession with their job related duties. If you are not an electrician, we are not permitted to help you perform your own electrical installation or maintenance work.
