Hey so I don't have a lot of time to read through forums but I'm re doing wiring for well pump just from top of well case underground into basement to pressure switch..
My question is type of wire to use I thought uf? Right now it's just wire nutted at top of well do you normal install a junction box? Also is it okay to run the uf through conduit underground into basement to the pressure switch.
