tjacobs
- Moorestown, NJ
Had a new well drilled at my house and a submersible pump installed. The well pump contractor ran the following wire from the pressure switch to the outside and down the well casing to the pump.
Three conductor twisted with no jacket.
Looks like RHW conductors.
The wire is run exposed and attached to the water line with bands of cheap electrical tape in the basement.
The wire passes through my basement wall and is direct burial to the well casing,
Approx 12" burial depth.
How do the well installers get away with this type of installation ?
When I asked the guy about the exposed wire the answer I got was "That's the way its always been done".
