When I brought out my generator the other day, I started it up and measured the output voltage. It was reading 180+ volts on the 120V receptacles. It was reading 300+ volts on the 240V receptacle. I manually moved the governor down and the engine was barely running to achieve 120V. Can I assume that the voltage regulator is faulty?
