wirebender
- North Central Texas
Does an under counter refrigerator in a wet bar have to be on a dedicated circuit? GFCI receptacle?
haskindm said:Check 210.8(A)(7). The section that said that GFCI was only needed for "receptacles that serve countertops in the area of a "wet bar" sink was removed in 2005. Any 15 or 20 amp 125-volt receptacle within six feet of a wet bar sink must be GFCI protected. Even if it is a single receptacle. Even if it is behind the refrigerator. Even if it is a twistlock receptacle. No exceptions.
wirebender said:Does an under counter refrigerator in a wet bar have to be on a dedicated circuit? GFCI receptacle?
raider1 said:Agreed, I have to explain this quite often when I call out for the receptacle feeding a refrigerator next to a wet bar sink (Within 6') to be GFCI protected. Same with the microwave outlet in the cabinet above the sink or next to the sink.
Chris
dcspector said:What theory/intent do you mention? Or do you simply say because it's in the code. What basically is the difference between a typical wetbar layout, as you mention, and a Kitchen layout? ie. refrigerator receptacle and receptacle in a cabinet above the sink.
480sparky said:Kitchens are different from wet bars.
raider1 said:I don't pretend to explain or justify the differences in the code, just enforce the code sections as they are written.
Chris
dcspector said:I understand Chris. Sometimes we just have no idea for the reasoning. This versus a Kitchen makes zero sense to me.
raider1 said:I agree. What makes a refrigerator next to a wet bar sink more dangerous then a refrigerator next to the kitchen sink?
Chris
480sparky said:There's more, shall we say, 'spirited' liquids associated with a bar? :grin:
Chris
celtic said:Do we know if this is a dwelling or non-dwelling location?
