I have some PVC conduits that I installed under a basement slab at a new build.
They will be used as sleeves to get wiring to some island areas that are located in a finished basement.
If using NM cable, does it still have to be type UF since both ends of the sleeve terminate in interior areas that have consistent temperatures of 70 or so degrees?
