e1coxjck
- Baltimore,MD
Is an exterior masonry/brick wall considered a wet/damp location? How about the 1" air space between the masonry and insulation? Gist of question is the use of sheet steel boxes in exterior walls and the use of gasketed cover plates on these boxes. Brick/masonry exterior walls are porous have weep holes and are therefore I would think at least a damp location. Sheet steel boxes are not water tight and do not mate well with gasketed cover plates. Gasketed cover plates do not provide a watertight seal on porous masonry surfaces. Would the NEC require a weather/water tight box for this application? Standard practice seems to be a sheet steel box with a weatherproof outlet cover which I do not think meets he NEC requriements for a wet/damp location.
