A/A Fuel GTX
- WI & AZ
- Electrician
I have a new house that will be fed from a pedestal 60' away. I'd like to come out of the pedestal with an underground run of 2" PVC, sleeve the foundation wall ( below grade ) with 2 1/2" and go straight into the panel in the basement. I know underground wiring is considered a wet location and even if all the couplings are properly installed, some moisture will be present within the conduit. My question is this, will I be asking for trouble later with maybe some water in the panel since the conduit will come straight into the enclosure with no 90's or LB's to hold the moisture back? I realize I would have to seal the sleeve where the 2" goes through the 2 1/2" PVC in the foundation wall. Any thoughts?
