M_J_C
- Southeast Florida
The article 100 definition of "Location, Wet" includes 'installations....in concrete slabs.....in direct contact with the earth'.
Lets say we have ground level concrete slab, say 75' x 150' (the size isn't a deciding factor) and there is a basement under 3/4's of this slab. The ground level slab has PVC conduit embedded in for HR's and kitchen island's etc., some of those conduits turn down out of the this slab to be terminated in enclosures mounted on the basement walls.
According to the definition above, all of the conduits in the ground level slab would be considered a wet location, even if they were not in the earth or even in the portion of the concrete slab that is directly above the earth. This is a problem for phone and data wiring, because none of the indoor wire available is rated for wet locations and none of the wet location wire (flooded or direct burial) is rated for indoor use (cl2/3).
Also, if the conduits were really 'wet' wouldn't my biggest problem be water continuously pouring out of the conduits into my enclosures in the basement?
Am I missing something?
