stjohnbarleycorn
On the forming shell, there is a bonding terminal on the outside and the inside.
I am taking #8 copper to the outside, which I put (potting compound on) which in turn will be bonded to the metal wall of the in ground pool, and the rebar, pump etc., back to the panel.
I am running a #8 insulated copper conductor to the deck box from the panel. I don't have the fixture yet. Does the #8 insulated wire terminate from inside the forming shell, to the terminal strip in the deck box and then potting compound is put on the terminal in the shell, or is there a bonding wire from the fixture to that terminal in the shell, or both?
On the deck box there is an external bonding terminal, is it required to run the bare #8 to bond that to the rebar, pool grid?
thanks for any clarification on this.
